Correct? So you could be running lean and hot in the combustion chamber but the coolant guage could look find and dandy?
coolant temp doesn't indicate internal comb. temp?
Originally posted by deevergote View PostYou could be detonating in the combustion chambers and not significantly heating the coolant.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View Posthow is this ? can this be bad ?
Yes detonation is bad.
The combustion chamber is the inside of the Sleeve that the pistons run in.
The coolant system is the outside of the sleeve.
Detonation won't heat the coolant system up fast enough to directly show it on the gauge instantly.
As for the OP's question - The coolant temp is not directly/solely related to the internal combustion temp as it is also effected by other factors.
What you need to measure the internal combustion temp is a Exhaust Gas Temperature (EGT) Gauge for each cylinder, combined with a Wideband.
My 5.7 LS1 Holden Ute
