where did my power steer fluid go?
    I checked all my fluids every time i get gas which is about every 2 weeks. My power steer fluid was up to the max line one time i got gas and 2 weeks later it was a bit below the min line. Where did it go? Should i be concerned? I have never had to add fluid since i got the car. The steering system functions normaly btw.
    Thanks
    visit vgruk
    crawl under your car and look for a leak!
    look at where the lines go into the rack, to the left of center. the is a shield that covers them with a hole in the middle. I had the high pressure line rust out on my sedan.
    running the pump dry will ruin the pump.....
    also, only use honda power steering fluid. From what i have read the pump and steering rack don't like the universal stuff..
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      I have noticed no leaks at all. Thats my problem sorry i should have put that in the first post
      visit vgruk
        well, it has to go somewhere! it's a closed system. it can't just disappear..
          I know right! I will get under the car and look.
          visit vgruk
            Power steering fluid has nowhere to go unless it's leaking. It is a sealed system, and is incapable of burning anything. It could be leaking from the pump, the lines, or the rack. The rack is probably the most likely (and you may need to replace the entire rack... I've seen them fail in much younger CBs!) Chances are that it's only leaking when under load, so you may not see anything if you just park it and look for a leak. Fill it up, put some cardboard under the front, and start the car. Turn the wheel back and forth a number of times, loading the system. If it leaks, that's when it SHOULD do it. Our power steering systems work the hardest when the car is stationary.
            When you locate the leak, inspect all areas that the fluid leaked onto. Power steering fluid is corrosive, and should be thoroughly cleaned from any painted surfaces, as well as any rubber/plastic parts (especially wire sheathing.) If the painted areas are already bubbling, you'll need to sand them down and spray them with primer to prevent rust.
            And yes, Honda fluids should be used for EVERYTHING, save for engine oil and hydraulic fluids.
