brake upgrade?
    brake upgrade?
    Hey, i was thinking about brake options. i have a 93 lx with the rear drums, i was first thinking ex rear disc conversion, but is there another brake option? i was hoping something similar to the 300zx brakes on 240s, but something for a cb7.
    anything like that out there?
    thanks
    This should help. http://www.cb7tuner.com/vbb/showthre...pgrade+options
      Go to www.tasauto.com and look up their performance brake kits. They are expensive but TAS is a very reputable company and gives us aftermarket support which is rare. Id imagine their top of the line ROH Drilled Big Brake kit is among the very best you can buy.
        Far from the very best... but more than anyone will ever truly need on a street car, for sure.
        You can also use upgraded front brakes from a wagon, which are larger. Some people have installed NSX front calipers as well.
        Honestly, though... brake upgrades can be tricky, and they can actually hurt a car's braking performance if done incorrectly. Unless you really understand braking systems, and you plan on using your car in a way that will require a considerable upgrade (such as road racing, or serious autocross racing), then you might be best leaving them alone.
