92 Accord Wagon jdm H22A swap randoms
    i just purchased a 92 accord wagon. had a H22A swapd into it. it is a 5spd. it has power steering, ac and cruise that works. im interestd in knowing what prelude my engine came out of so i can buy parts at parts store. also, what do i purchase an intake system for to fit with only minor to no mods to system. and last, what short shifter should i be ordering to fit.
    a h22 is a h22. look between the exhaust ports on the head and youll see the date the motor was made. that will tell you what car it came from.
    a prelude intake will fit. a short ram is easier than a cold air.
    dont get a short shifter.
      its stampd 97, but theres no listing for 97 Vtec motors at any of the parts stores.
        your parts store clerk is a dumbshit.. 97 prelude only came with vtec
          Leave Autozone and go somewhere else. What engine parts are you needing?
            that there is your answer. any engine part for a 97 found at any parts store will be what you need. unless you arent in the us or canadia
              If you know the year (1997 from what you said) then it doesn't matter what Autozone says because when they look for parts in their computer system there is a drop down menu with make, model, year, body type and engine. The employees don't need to know anything because the computer tells them what they need to know as far as parts go.
              Are you talking about an air intake? Just buy a cheapo short ram with a quality filter.
              I believe Neuspeed makes a short shifter, some other companies also. There are also a couple of short shifter DIY"s here on the site. And if you didn't know already CB's short shifters don't have shorter rods, they just make your throw shorter. If you want an actual shorter rod then you will have to do it gangster style and cut it down.
