N.H!! swapping automatic to manual rear motor mount wont match hole on to the bracket
    i have a 92 accord and i swap my automatic tranny with a manual tranny before and i was having problems so i had to leave it automatic so now a year later im doing the same thing , swapping it again but yet i feel like the same thing is going to happend, so i have all 3 manual motor mounts the 2 that go on each side and i bought the rear one new so far the two on the side were hard to go in and the rear one dosent match the hole wat am i doing wrong or wat do i need
    The rear mount bracket is different for AT and MT. And for the tranny mount you need a cd5 MT mount or a ESP mount or have the manual bracket welded to the frame.
    STANCE|WORKS
      im also using the same bracket wee took off the manual cb7
        Well if you have the correct mount setup. You just have to play with it like jack up the back off the tranny or on the side or take off the tranny mount and put in the back one and then put on the tranny mount.
        STANCE|WORKS
          U think it would be better if I also change the crossmember from the Manuel cb7 cause they look different but I heard it Doesn't matter
