Just wanna know which headers are better.. 4-2-1 or 4-1 and which ones did the cb7 come stock with?
4-2-1 headers Vs 4-1 what's better?
Originally posted by Mr92cb7 View PostJust wanna know which headers are better.. 4-2-1 or 4-1 and which ones did the cb7 come stock with?
Originally posted by Mr92cb7 View PostOkay so I'm pretty much better off replacing the stock ones right now.. But a buddy of mine said the 4-1 is better than 4-2-1 performance wise.. Is this true?
Originally posted by cloudasc View PostIt depends upon the headers design, and application. My bisimoto header is a 4-1 design, its considered the best header available for the f22ax, then again it was a custom made header based upon a spec sheet I submitted at purchase.
Originally posted by Mr92cb7 View PostOkay cool.. I'll just have to check some out.. Dude I was just watching your YouTube vid with your cars acceleration hahaLast edited by cloudasc; 06-03-2012, 12:47 AM.
Originally posted by cloudasc View PostGlad you enjoyed what you saw, though the setup I am running right now (bisi header not installed yet) is an a1 converted to a6, but its biggest drawback/restriction at this time is the a1 header (and possibly stock airbox though a k&n panel is installed), my hp flatlines before I reach 6k at 110whp on an auto in 100 degree heat (there is also a dyno video/chart, so you can use my mrt kinda as a template/example for the not so obvious/common things done to increase power besides intake/exhaust). If you haven't already, you should read through the stickies at the top of each section, as they contain some of the best/most valuable information you could almost ever want to know, like the 30hp for under $500 thread.
Keep in mind that if you switch from a 4-1 (A1) manifold to 4-2-1 (A4, A6), you need a different flex pipe and the bung for the O2 sensor moves from the bottom front of the manifold (A1) to the flex pipe (A4, A6) and you will either have to undo the wiring harness to route the existing plug behind the engine, or make up a jumper harness.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
