F22-SOHC Vtec?
    F22-SOHC Vtec?
    I was on CL and was looking for something when I came across an sohc F22 vtec engine ?
    Is there such thing as that? Or just an error
    If there is such thing wouldn't that mean that it is a direct head swap to the f22a series?
    I always though there was the f22a sohc that comes stock in our cars (non vtec only)
    And then the F22b which are the dohc
    f22b1 VTEC and f22b2 non-VTEC are 5th gen accord engines both SOHC.
    MadLab Racing
    Southern Maryland
      I thought 5th gens were f23?
        Nope, 6th gen.
          Originally posted by dj_ender View Post
          Nope, 6th gen.
          O ok thanks for clarifying that
          So then that f22 sohc vtec is just an f22b series engine pretty much?
            Your a little confused, the F22B is a JDM DOHC. The F22B1/2's are USDM SOHC engines. They are very similar to the F22Ax's, except the F22B1 has VTEC.
              Your a little confused, the F22B is a JDM DOHC. The F22B1/2's are USDM SOHC engines. They are very similar to the F22Ax's, except they have VTEC.
              F22B2 didn't have vtec.
                Shhhh
                  Wow I really was confused, but yeah I knew there was a DoHc f22b just wasn't sure which one
                    The F22B1 (VTEC) is crap compared to the F22A. SOHC VTEC is pointless. Intake valves only.
                      Really? so is that only the F22B1 or All SOHC VTEC, Intake Valves Only.? I was debating which to go with Single or Dual OHC but,... I see a lot of peeps with H22 swaps.
                        All SOHC VTEC systems are like that (current models may not be... I believe my L15A is SOHC with both intake and exhaust... but that's a very different engine...)
                        The F22B1 has intake-only VTEC, restrictive ports, crappy valve angles... that engine is only good for reliability and efficiency (and for that, it's very good.)
                        If you want to swap, get an H22A. It's popular because it's the most power you're going to get in a swap for the least amount of money. It's easy to find, easy to repair, and available in the US, so you can find replacement parts at Honda dealerships and autoparts stores.
                        Don't worry about being unique... you drive one of the most popular cars on the road.
