92 accord stock wont run
    my accord wont start i thought it was the ecu swiched it and steal wont start main relay and steal noting i got fuel presser and spark it just cranks and cranks doesent even wana strt help
    dead battery? bad starter?
    92 Honda Accord LX - Sold
    2005 Nissan Altima 2.5S - Sold
    2007 Dodge Charger SXT
      we need to know alil more about your car is your car automatic or manual
        Holy shit. Slow down, read what you write before you hit that "submit" button, and please TRY to make sense. Those aren't even words!
        You need fuel, spark, and compression... one is lacking. Figure out which one.
        Is your check engine light on? If so, pull the code.
        Stop throwing random parts at your car until you KNOW what the problem is.
          I think it might be the same thing that I had a problem with along time ago.
          My timing skipped and well I think it has happened to me again. This is shit.
            If it is timing have a second person help you and try rotating the dizzy while some one turns the key
              i fixed my issue. But what the dude is describing sounds like the timing belt skipped but dont jump to conclusions till you diagnose every thing.
                Check for compression.
                A&P-IA
                  how do you know you have fuel pressure and spark ? if you did those test we need to know the results.
                  A lot of things can make the engine crank but not start.
                  10th Anniversary Accord.
                  05 Audi A4 Ultra Sport 6MT.
                    service port on fuel rail and spark plug on the wire to the block. youll see the spark from the plug to the plug. and fuel will spill out of the service port btw. dude I really think its your timing belt of you have fuel and spark. Reason is that same shit happened to me had fuel and spark but my timing was off.
                    I revved the shit outta my car once and it was at 7k rpm and turned it off then it just fucked itself. with my help lol
                      my bad im new at this
                      ok my girl was driving and she said it sound like rocks under the hood never ran agin.checked fuel presh good had strong spark and no codes heres what i thought about what happend. a year ago my altanater fuk up fried my ecu got it rebuilt fuk up agin not charging rebuilt it agin about 2 months ago something broke off in it and it fell out so thats why i thought it was my ecu/main relay replased them both and nothing pryed the timing belt cover back and its not broke
                        puled the spark plug out and opend the gas line and its auto
