Wish I could find one of these elusive a7's I don't have any emissions where I live and it would be so nice to start with 150hp
wanting an a7 so so bad....
F22A7 is that from europe or something?
A6 is 140hp.**Blk Housed Slut Crew Member #1**
I'd go for an F22B DOHC.
F22B
This engine was used in the 1992–1996 Honda Prelude Si in Japan. It is similar to the H23A.
Specifications
2.2 L
Bore × Stroke: 85.0 × 95.0 mm
Displacement: 2156 cc
Valve Configuration: DOHC, 16 valves
Compression ratio: 9.3:1
Max power: 166 hp (119 kW) @ 6000 rpm
Max torque: 150 lb·ft (200 N m) @ 5000 rpm
That and this engine is probably easier to find than that unicorn of an a7.
The difference is higher compression (9.3:1 vs. 8.8:1) and likely the same cam that's found in the F22B5/8.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I can't name 5 ppl who have a 2.0 on here.**Blk Housed Slut Crew Member #1**
And I almost bought an F20A DOHC too...I would have been one of few with one on boost. I may still do it since I know the specs of it and all. Just to be different.The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
I think one of our European members has an A7.
says he has an A7, but he's in Washington. dumbass wants to go H22 turbo, so he doesn't appreciate having a unique engine. Probably scrapped the car by now.
Can't find anyone else that says they have an A7. I think it might be the aerodeck (wagon, essentially... the CB8, I believe) engine... but I don't know anyone with one here.
I was mostly wondering because The wiki stuff says is because of the emissions stuff here in america. well where I'm from we don't have to pass emissions so I wouldn't have to worry about it and would have more power to start with.that's the main reason I asked and yrs I did find a thread about it but it had been closed.
Originally posted by 8ball View Posta6 with h23 pistons ... tada!
not worth being that cool but yu kan alwayz send me yourz moniez!!!
Edit...they are.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally Posted by wikipedia
F22A
This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar.
Specifications
- Bore × Stroke: 85.0 × 95.0 mm
- Displacement: 2156 cc
- Valve Configuration: SOHC, 16 valves, Non vtec
- Compression ratio: 8.8:1
- Max power:
F22A1: 125hp @ 5200 rpm
F22A4: 130hp @ 5200 rpm
F22A6: 140hp @ 5600 rpm
F22A7: 150hp @ 5900 rpm (147hp/108kW with automatic transmission)
- Max torque:
F22A1: 137tq @ 4000 rpm
F22A4: 142tq @ 4000 rpm
F22A6: 142tq @ 4500 rpm
F22A7: 145tq @ 5000 rpm
not worth being that cool but yu kan alwayz send me yourz moniez!!!Originally posted by dj_ender View PostAren't the H23 pistons for FRM cylinder walls?
Edit...they are.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
