your tires dont rub when your turning? wow im lowered 2 inches and have 215/45/14 right now and they rub. mabye -1.25 front camber
ingalls adjustable ball joint camber kits suck
Originally posted by sepulveda87 View Postyour tires dont rub when your turning? wow im lowered 2 inches and have 215/45/14 right now and they rub. mabye -1.25 front camberLast edited by Accord problems; 06-13-2012, 12:07 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
I ended up modifying the shock towers. Yes my car is pretty low but not unsafe in anyway. My suspension can travel fully. With the front camber kits fully adjusted I get 2 degrees of camber, I was hoping for 1.5 but its not to bad. Like someone stated earlier as long as toe is adjusted correctly tire wear will be minimal.My whips so clean I can see the reflection of your car in the reflection of my car on the reflection of your car
