A/C CB3 in CB7
    A/C CB3 in CB7
    Hi Guys!!!
    I Crash my CB7 93 (F22A6) and... i broken the condenser, fan condenser and... hoses and cooling lines.
    In my country... the NEW Air condenser OEM cost U$S 1300...
    Well i found a CB3... With F20... No SRS
    Is possible change the A/C System (Condenser, hoses and lines) and put in my CB7??
    I have got a F22 Compressor.
    thx!!!
    are they both the LHD or RHD?
    Most likely everything should work just fine. The compressors might be different between the two but i highly doubt the hookup point on the condenser is different. The soft lines going to the compressor MIGHT be different if the compressor is different. You will just need to keep an eye out
    SRS won't make any difference since our airbag sensors are located on the inside of the car along the firewall.
      I would go on-line and log onto online OEM parts store like Majestic Honda. Check for part numbers and compare of the two cars to see if two compressors are the same part number or not, along with other parts you need.
      You could eliminate guessing work.
      A&P-IA
        Majestic Honda is just a Honda dealership in the US. They will not have CB3 part numbers.
        The parts should be interchangeable. The only issue will be, as tippey said, if the steering wheel is on different sides between the two cars. To my knowledge, all CB7s are LHD, and all CB3s are RHD... but I'm not an expert.
          Well, I was not aware of CB3 being RHD. But still, my idea maybe valid that there may be an web site in his country where he could check part numbers on both cars, provided that CB7 and CB3 are sold from authorized Honda dealers in Argentina.
          A&P-IA
            They both are LHD. All imported CB3 to Argentina are LHD with engine F20xx.
            Is a good idea!!!
            I search and found it... the compressor aren't the same...
            38810-PT6-A04 is for CB7 aaaaaand...
            38810-PT0-013 is for CB3...
            Weeeeeeeeeell... i will going to search more to find the condenser, hoses, cooling lines, and fan condenser to CB7 93.
            A/C CB3 in CB7 not work with F22 compressor and F22 condenser.
            Well guys, thanks for help me!!!
              OH hey!
              It seems like, I, did, contributed something good to others for a change.
              A&P-IA
                Is a good idea!!!
                Just because the compressor is different doesn't mean the condenser is different. I would take a look at the two cars and see how similar they are before you give up.
