Loud clicking
    Loud clicking
    Whenever it's hot out and I am not actually driving, (stop light, stop sign, etc.) what I think is the fans are making a really loud clicking noise like they Re hitting something. I can turn them manually without them hitting anything so that's where I get confused. Sometimes when it's hot and I get back from a drive and turn the car off this problem will start up, and will proceed for 10+ minutes. Also when I turn the AC on its very loud, and the clicking will sometimes happen.
    how can u tell its the fans ? u might be lookin in the wrong place
    10th Anniversary Accord.
    05 Audi A4 Ultra Sport 6MT.
      I can't tell what it is. I guessed it was fans cuz its when I use ac or when it's hot so I figured it was trying to cool down.
        The bearings in the fan may be shot. Check to see if there's any play. In the worst case, grab some junkyard replacements. They can't possibly be too expensive, and the fans aren't common things to fail. It's likely junkyard fans will work just fine.
          Iv'e had my fan blades hit my positive wires on the harness. I just moved them till they were clear of the fan. Hopefully it's as easy as that.
            yea ,, it can be the bearing because u spinnin them manually doesnt actually turn them like the motors do
              My radiator fan motor went bad last week. Aft bearing departed from the motor and the fan was hitting the frame. it was making loud noise. I replaced the motor with new unit from Advance Auto.
              There are photos from the replacement job in my MRT. if it helps.
              http://www.cb7tuner.com/vbb/showthre...=188476&page=2
              A&P-IA
