I replace my tranny because the last one went bad as I was taking it out one of the axles broke. So went to advance auto and replaced it because it was undef warranty .I finnaly got the cb running yesterday but I notice when I turn ill hear a bi loud bang coming from where the tranny connects, I found out that they gave me a 92 axle which is a lil shorter so went back and got a 94 lx one since um using a p2a5 tranny , I replaced the input seals but I'm having this problem http://m.youtube.com/?client=mv-goog...?v=KsEh7MeDQuQ I'm still hearing the bang but not as loud . Can someone help me please ?
major axle issues (video)
From Wikipedia:
CB
Width
1990-91: 67.9 in (1,725 mm)
1992-93 Coupe & Sedan: 67.1 in (1,704 mm)
1992-93 Wagon: 67.5 in (1,715 mm)
1,695 mm (67 in) (all bodystyles in Japan)
CD
Width
70.1 in (1,781 mm)
Though the width of the car itself (which is what those measurements are) isn't necessarily the width between the left and right wheels... Still, I found the varying CB7 width interesting, so I wanted to share! I wonder where that width comes into play, since most body panels are interchangeable...
i replaced my axles with 90-93 axles but i have a different problem, now that they've been changed the steering wheel vibrates just a little when in roads but a lot when in freeways someone might know why?? thanks......
MRT Thread: http://www.cb7tuner.com/vbb/showthread.php?t=193631
My fs thread: http://www.cb7tuner.com/vbb/showthread.php?t=190359
Originally posted by bigbozz24 View PostI replace my tranny because the last one went bad as I was taking it out one of the axles broke. So went to advance auto and replaced it because it was undef warranty .I finnaly got the cb running yesterday but I notice when I turn ill hear a bi loud bang coming from where the tranny connects, I found out that they gave me a 92 axle which is a lil shorter so went back and got a 94 lx one since um using a p2a5 tranny , I replaced the input seals but I'm having this problem http://m.youtube.com/?client=mv-goog...?v=KsEh7MeDQuQ I'm still hearing the bang but not as loud . Can someone help me please ?
my car hasnt been wrecked. Deev i was using 90-93 axles and every time i turn it felt like my axles were coming out. my biggest concer about the video is the amount of play it has. Is it normal or it shouldnt have that much play. with the 90-93 axles when i turn fluid comes out . I put a honda oem axle seal so i doubt thats bad.Any other suggestions . i have no problem using my 90-93 axles but they seem to be a bit shot and its only on the passenger side because on my driver side im still using the 90-93 axles and its fine . note:im using a auto trans bracket with a manual tranny p2a5 that uses a mount long enough to bypass the welding since EsP cant help me.I dont want to go H . my engine sit level with this tranny. it only does when turning.While driving normaly its perfectly fine no matter the speed its only when i turn.
Originally posted by deevergote View PostFrom Wikipedia:
CB
Width
CD
Width
70.1 in (1,781 mm)
