i was going to put a obd1 h22a in the 92. but i heard i would have to wire in the vtec, knock sensor, and something else. bcuz the car didnt come vtec!.. would i have to wire all that in if i used the h22 harrnest and computer??
wiring questions.
You cant change the whole harness to the ecu as in The wire is not in the part of the harness that goes from the ecu to the engine harness so it even if you use the h22 harness it wont work. You need to add the wires to the plug in the back of the ecu and run them into the engine bay and hook them up to there sensors or what ever they control. Idk about the knock sensor but I think you do need to add it but I know you need the vtec solenoid wires up and the vtec oil pressure switch.
I think this is the same for all obd1 pinouts
Uploaded with ImageShack.usLast edited by thepowderblue; 05-05-2012, 05:37 AM.
Originally posted by MCNELLY View Postalright thanks.. i notice it said b16 and gsr.. is this for genral or just these motors?
[QUOTE=deevergote;2990821]Exactly. Much of what thepowderblue has said (along with similar images) can be found in the "sticky" threads found in the Swaps section. This has been covered in extensive detail, honestly.
well my bad bro. it was late last night and i didnt feel like playin with the swaps section,
Originally posted by MCNELLY View Postlazy. yu dont even know what i did yeasterday.....
so im lazy cuz it was 3 or 4 in the mornin asking a question about wiring to see if anyone was nice enuf to help me out, whitch their is. but if i WOULDA KNOWN I WOULD HAVE DEAL WITH A D BAG LIKE YU I WOULDA STAYED OFF
