Aftermarket cat back with stock muffler?
    Hi all,
    I have noticed that my muffler has become rusted and sounds terrible, definately needing to be replaced. I cannot swap it out becuase it is welded on so I have decided to order aftermarket parts, a spec-d tuning cat back system to be precise. I know it's a cheap kit but I am wondering is it possible to bolt a stock muffler onto the aftermarket mid pipe? Has anyone done this before? Also, does anyone have experience with the spec-d exhaust? If it doesn't sound too ricey I may just forget the stock muffler. If not I'll be sure to review it when it arrives. (car is a 1991 LX sedan if that matters.)
    So you say that your muffler is welded on, then you go and say can you bolt it up to the aftermarket piping? No. If it is welded on, you cannot bolt it on.
      not all systems are the same, MOST are bolt-together so yeah, a stock-type muffler could be subbed in i'm sure
      at the very worst you get a shop to flare one end so you can bolt it together if they aren't already
        I'm assuming the Spec-D is one of those eBay brands. If so you cannot bolt a factory rear section to the 2.5" piping. The factory piping is 1.75". I recommend you get a Magnaflow or Dynomax muffler that's made of stainless and has a 2.5" inlet and just replace the muffler itself on the Spec-D exhaust and not the whole axle-back section.
        Edit* What?! That was a random time to creep back out of the woodwork.
        To clarify what I meant in reflection of Deev's post below by "replace" I meant weld.
          Fizzy!
          It's unlikely that the aftermarket setup will bolt to the stock muffler without some custom work. It CAN be done, sure... but honestly, why would you even want to? There's no performance gain to be had by doing that. Hell, you might actually even lose performance, given the turbulence that would be caused by the sudden change in pipe diameter at the very end!
          Since you already ordered that SpecD kit, I say just install it. It WILL sound like shit. All those cheap kits do. It will be loud, and if it doesn't rasp you'll be lucky.
          If you want quiet aftermarket, go for the Apexi World Sport 2. It's not cheap, but it's well made and sounds good.
          Ultimately, you get what you pay for. Unless you're a complete sucker, that is.
            Fizzy!
            this right here. my experience with other cars though suggest that you can run the axleback to an aftermarket midpipe, but with the reduction in diameter, it's not worth it. just run a full catback
              Thanks for the feedback. Looks like I'll just have to live with a loud exhaust for now. Can't possibly sound worse than it does now though! The kit does come with a silencer for the muffler. Do those work at all like you would expect them to?
                Typically the silencer is just an insert into the muffler and fastened with a small bolt and nut. Putting the silencer in will negate the performance the cat back gives you due to it restricting the airflow. They do work as far as making the car quieter, but sometimes the silencer can rattle during acceleration and as I mentioned before you will lose most of the performance gains had by the cat-back.
                  You can also go to your local parts store and purchase a muffler. Most of the performance mufflers have 2.5" ends so all you would have to do is weld it on. This will give you performance and a nice deep sound as long as you still have a catalytic converter and resonator.
