What does gas look like when it leeks out of a injector and dry's out ? Is it a white ?
Car safety checks
Fluid CapacitiesTags: None
Ok thanksthis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by deevergote View PostCorrosion/oxidation on aluminum is white.
Deposits caused by coolant burning in the cylinders could be white.
all of them.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
