Clicking noise
    Clicking noise
    Every time I make big turns i hear click click click noise. Last time this happen I replaced both right and left axels. I replaced these 6 months ago. Could it be possible I have to replace again already?? What else could it be?
    Totally sounds like a CV joint. Do you have a motor swap?
      Clicking when turning is usually a bad CV joint, yes. Try getting brand new axles, or remanufactured axles from a better source than you used before (the usual autoparts store remans are known to be iffy at best.) NAPA usually has good axles.
      Are you sure you installed them correctly? Do you have an engine/transmission swap that could potentially be causing problems due to improper installation?
        No motor swap.
        I got my axles from autozone, and I had a someone help me install them. We did install them correctly. I have not had any swap, but my transmission wines a lot, and ammco said I need a new transmission, if that info is relevant.
