Hey Cb7tuner. I have a oil leak coming from my engine. Long story short I looked over as much as I could with the engine in my car.
This is oil gunk under my distributer.
Oil gunk under the engine near the (CV joint.. I think?) on the passenger side
This is under the driver side of the engine bay
This is under the oil pan. There is fresh oil on the bolts.
This is my first time dealing with these things.I came to the conclusion that this could be because of the gaskets. Hopefully. The only place I recall seeing fresh engine oil was on the bolts of the oil pan. Everywhere else is crude gunk. I know when I got my first oil change the mechanic told me the oil pan has a stripped bolt, so they plugged it up with a rubber seal thing. It's a temporary measure until I could figure out what to do.
What do you guys think it is? Is there a "common" engine leak area?
