Hey guys, my 91 EX CB7 is having a bit of a steering issue, i searched around and i didnt see much, The problem i am having is When i take a Right turn my steering wheel alignment turns to the left as if it was straight and when i take a left turn after that it goes back to normal. My question is could it be that when I take a Right turn My Rack and Pinion moves because my Bushings are too gone? Can it be the Steering Rack, My guess is that its the Rack and Pinion Bushings but idk And if its it where to buy them from, Dont say Ebay
Rack and Pinion Bushings?!
Originally posted by EFSOHC View PostHey guys, my 91 EX CB7 is having a bit of a steering issue, i searched around and i didnt see much, The problem i am having is When i take a Right turn my steering wheel alignment turns to the left as if it was straight and when i take a left turn after that it goes back to normal. My question is could it be that when I take a Right turn My Rack and Pinion moves because my Bushings are too gone? Can it be the Steering Rack, My guess is that its the Rack and Pinion Bushings but idk And if its it where to buy them from, Dont say Ebay
I get my parts from my older brother because he gets a commission on tires and parts even though he is reselling me the parts at whole sale price. So it's like Win Win for the both of us but yeah i have also ordered from all three of those companies i mentioned above.
hmm...just for kicks...check or retighten your lugnuts? Maybe they're a little loose? GL!
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
I'm just trying to see if this has happened to anyone, imma have to get under there this weekend, most likely going to get a kit from TAS Thanks for the input
Originally posted by Leung View Posti can't really comment on your steering issue but most of the people on here order from Majestic Honda, TAS or RockAuto.
I get my parts from my older brother because he gets a commission on tires and parts even though he is reselling me the parts at whole sale price. So it's like Win Win for the both of us but yeah i have also ordered from all three of those companies i mentioned above.CB will be out beginning of March
Considered a wheel bearring or ball joint? If its noticeable in the steering, you should be able to find it pretty easy.
in my experience you would have very consistant issues and noises if the bushings in the rack were bad. Seems more likely you have an issue with either an upper ball joint, lower ball joint, inner or outer tie rod or a wheel bearring.
Thats my thoughts. It'd be pretty easy to diagnose prior to replacing the bushings on your rack.
Jesus thats a PITA.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
I'm just goin to buy almost everything ball joints, tie rods, camber, bushings etc. my steering should improve
Originally posted by toycar View PostConsidered a wheel bearring or ball joint? If its noticeable in the steering, you should be able to find it pretty easy.
in my experience you would have very consisall tant issues and noises if the bushings in the rack were bad. Seems more likely you have an issue with either an upper ball joint, lower ball joint, inner or outer tie rod or a wheel bearring.
Jesus thats a PITA.CB will be out beginning of March
Originally posted by EFSOHC View PostI'm just goin to buy almost everything ball joints, tie rods, camber, bushings etc. my steering should improve
Jokes aside, I think you should first test for symptoms, verified the problem then replace the part that is causing the problem. Throwing parts at the car won't diagnose it, and can be expensive. At the same time you are performing work that is not necessary.
Good luck with your investigation.
Just like me, I have this rhythmic sound/feel in my driver's side. I tested for bearing, axle, ball joints, tires and bushings. Absolutely no play or symptoms of what is causing it. So at least I know it's safe to drive it until I come across the actual problem when doing some thing else later maybe. Today I sand down the rust on my hub and little on the back or my steelies. If that doesn't fix it, then I'll replace the end links. They are still together but with cracks, but functional. The only movement I have is when I tug on the sway bar, which should have a little movement in it.
Originally posted by Bad_dude View PostYou should go to the part store, tell them your year, make, and model. Then tell them you want all of the parts on the car. Take the cart full at a time and start throwing them at the car until it fixes the problem. Once it's done, come back here and tell us which part you replaced fixed the problem.
Im sure you did a good inspection, so dont take me wrong here.
Sometimes an issue on the passenger side, particularly wheel bearring, can cause an odd sound coming from the drivers side. It works both ways actually. Basically, if you hear something on one side, dont just assume the cause of it is only on the side you hear it coming from.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Originally posted by toycar View PostIm sure you did a good inspection, so dont take me wrong here.
yah I have to buy axles too
Originally posted by Bad_dude View PostWhat do you mean don't take you wrong? You are trying to help me so there's no wrong in that. Thanks for the pointer. I thought of that since the passenger's side axle was replaced almost a year ago but for $90 including part and labor, I bet it's a reman one. Though no boots broke noticed, the sound is very uniform per rotation and constantly the same. It's just recently happen more pronouncedly. It's feel like either axle or bearing but more like axle as it could be the bad teeth in the axle. There's no symptoms of a bad axle that I have noticed. I check by moving the axle outer and inner part and no play or movement. I cannot make a video as the sound is not loud enough for the smart phone to pick up.CB will be out beginning of March
