I have to extend my fuel hose that goes from the fuel filter to fuel rail. I'm looking at the different hoses online and was wondering what kinda hose I should get? Any specs on one or help is appreciated. If your wondering,I have to extend it due to the banjo is on the drivers side on the f23 I'm dropping, thanks
fuel hose psi?
Originally posted by Sordz View PostYou shouldn't see over 50psi stock. But I agree since it's the feed side of the fuel line either get new oem parts or the proper type hose.
Originally posted by oksleeper View Post2 options to consider...
#1 buy a FI hose thats got fittings on it, I believe O'reillys makes them
#2 buy a fire extinguisher so you can escape when you burn your car cause a regular hose clamp came loose.
Just my opinion
My best recommendation, its way overkill, but you can have a custom hydrolic hose made for that length you need, with whatever connectors you may need on the ends. Good to 400 bar, or 5800psi.
I had one made for to use an aftermarket oil pressure sender.
^^ That hose was $24, its 2ft long, with 1/8" npt connectors.Last edited by cloudasc; 04-24-2012, 01:19 PM.
