Strut queston
    Strut queston
    So today after visiting my uncle I noticed some squeeking in my suspention
    My right strut seems to be bouncing above the mount , in the hood area the strut is bouncing about a 2 fingers high what's up with my car is it a mount the car seem to ride the Same but I'm not sure if I have support from my strut anymore
    Originally posted by evil_demon_01
    Do it once, do it right.
    Saving a dollar is not worth risking a life.
    Missing My
    White -91 LX Sedan - leather converted
    Mulberry 91 EX Sedan
    The project 92
    I'm really not sure what you're asking...
      What I'm trying to ask is how do I know if a strut mount is bad , I know I should not have any of the strut in the engine compartment other than the bushing at the top il post pix tomarrow
      Missing My
      The project 92
        If the rubber is torn, the bushing is bad.
        If your shocks are original, then it's more likely that you have a blown shock than a damaged mount/bushing... but either is possible.
        Really, all you need to do is look at it. If looking at it while installed doesn't tell you anything, take it apart and look at it.
          Youre gonna have to pull the strut and diagnose it. If you pull off the top hat and chunks of rubber fall out, well there ya go. If the strut goes down super easy or just never comes back up then bingo. Just gotta pull it. Shouldnt take more then 20mins.
            Just be sure to use a spring compressor for safety... disassembling a shock/spring assembly is very dangerous without one. That top nut can be like a bullet, and you're going to be looking right at it as you remove it!
              Also sounds like its possible that the nut isn't tightened all the way down on top of the strut hat. I've seen that nut back off a bit before on a friends civic. That'll cause the strut to rise up like that also. But...the bushing is also probably shot.
                If I understand this post correctly, the strut mount is shot. The strut should not, as far as I know, move two inches (finger widths) [U]through[U] the top hat into the engine compartment. I could be wrong but would trust Deev as he has his facts straight on hondas
