h22 main bearing problems
    okay,this is my fkng problem with the bearings i bought from ebay they are kingbearings , so when i first got them i figured that they were a lil bit larger than the originals that come with my h22a4 so i decide to moddify them cuz i work at a machine shop but when i finished all that i started to put torqe in the bolts at the bottom of the engine i notice that the crankshaft was stuck, so i decided to ask for help here anything will help, thanks
    So you bought the wrong parts, modified them instead of getting the correct parts, and now it won't work? Am I right? I'm not sure, because that run-on sentence of a paragraph is damn near impossible to understand.
    My guess is that you have a 1997 H22A4, with a 50mm main journal diameter, and you bought bearings for a 1998+ H22A4, which would be 55mm.
