Gas smell coming from A/c
    So took car on about hour and half drive and at the end I started smelling gas from the a/c vent. Anyone know the cause or experienced this? Thanks. I'm leaning towards evap core leak. But hopefully someone here knows more. Thanks in advanced.
    "Exhaust the Body, Proceed the Mind, Cultivate the Spirit"
    What kind of "gas" smell?
    Exhaust? Fuel? Freon?
    Did you loose a/c?
    A&P-IA
      Fuel. Open the good and no smell like exhaust. Under the car nothing as well
        Then, check for fuel leak inside the engine bay with engine running.
        A&P-IA
          Ok. Thanks.
            I had the same problem. When i did my fuel filter i noticed the vacuum line going to the charcoal canister was not hooked up. I hooked it up and the smell went away
            I attribute the smell while the a/c on to the fact that the smell only travels into the through the vents so when you run the a/c it grabs the smelly air and puts it inside although the smelly air is unrelated to the a/c
            The charcoal canister is designed to absorb fuel fumes by the way.
