autoshifter broken?
    autoshifter broken?
    I will be getting a 92 EX CB7 soon, the guy giving it to me says the the autoshifter is broken? Can this be replaced and/or easy to fix or is the tranny junk now? Not sure what kind of tranny it has,but the engine is a F22A6 if that info helps at all?
    He's most likely taking about the physical shifter, and yes it can be replaced. The best your getting has an auto tranny in it. I'm not sure, but I'd assume the auto shifter will be a tad more expensive than a manual shifter, there a switch or two on it.
      Sorry I should of at least specified what he told me, he said that the car wouldnt go into gear. Is this a normal problem for accord? Im assuming its just a loose connection
        Then I can't fully answer you, I'm not very familiar with autos. But from what I know, a bad tranny ECU (TCU) can cause the car not to shift, as well as the shift solenoids. And of course a bad shifter, all of which are easy fixes. You should ask if the D4 light is on/blinking.
          Ok thank you and what is a D4 light? That maybe a dumb question to ask lol, all I ever owned was 5-speed vehicles
            Park
            Reverse
            Neutral
            Drive 1
            Drive 2
            Drive 3
            Drive 4
            It's forth gear. You should ask if there are any lights that stay, I think there's also a Sports mode light as well, but not 100%.
              Park
              Reverse
              Neutral
              Drive 1
              Drive 2
              Drive 3
              Drive 4
              Ah ok,thanks for the information. I'll ask that lol
                Np.
                  I just messaged the guy, so hopefully ill have the answer by sun rise lol
                    Even if there are lights, you can go pull the codes and see what's wrong, could just need something cleaned or replaced. But that would require you go to the car.
                      Yea I am trading my DC4 Integra for it,by the looks of things I might have access to it by Saturday.
                        Use this DIY to read the codes and diagnose them.
                        http://www.cb7tuner.com/vbb/showthre...k+engine+light
                          Thanks for that link, I will be sure to use it
                            The guy is saying that there are no lights on or blinking?
                              So you are saying the seller is telling you that it won't go into gear? So basically its stuck in park, has he tried unlocking the shifter with the key and then going through the gears?
