f22a1 dohc!!!!
    92smokeaccord, I see what point you're trying to make but it doesn't really work. If I take an H22A1 head and put it on an F23A1 block what do I have? Nomenclature will tell you G23 or something like that. But that's not right. That's just what some idiot came up with one day and it stuck. To be technical, what would you actually have? A P13/PDE head on an F23A block. The title for an engine is to describe the sum of its parts. If it's not longer a complete unit then technically it can't be described as such. What you have for your setup is a PT2 head on an F22A block. It can't just be the average of the two names of the most major components. Not if you wanted to be technical, anyway.
      Wow ok thanks for awnsering the question if there was a dohc f22a1. And I know there's nothing to really gain from going from sohc to dohc I said I liked dohc they look better I wasn't getting it because it was better for boosting I just want a dohc it looks harder than a sohc
        The DOHC and SOHC are made of the same aluminum....
              I do agree, DOHC looks cooler than SOHC... but the SOHC head is capable of flowing incredibly well, possibly better than the DOHC, even.
              As for benefits of DOHC, if you ever get to the point where you understand how to adjust a camshaft, DOHC gives you control over intake and exhaust cams independently. SOHC controls both intake and exhaust valves with the same bumpstick, so if you advance one, you advance the other. If you retard one, you retard the other.
                DOHC allows you to adjust the overlap (good for n/a) or lack of overlap (good for turbo) between the intake an exhaust valves, to do the same thing in a SOHC, you need a whole new cam.
                One obvious benefit SOHC has over DOHC... less valve-train mass; and if you ever tire of the stock cam, you only have to buy one cam, not two.
                  I just bought a 92 prelude si 5 speed with an f22a1 dohc engine in it (which was rebuilt about 5000 miles ago). Now I know that this car did not come out with this type of motor and that there wasn't an f22a1 dohc made. So my question is what is the original motor supposed to be and does the engine that I have have an f22b head on it? And I was also wondering that if this is the wrong motor would that have any affect on the way the original transmission changes out, I've noticed the car has a hard time changing into 5th gear with a new clutch and pressure plate. Any help at all would be appreciated
                    Please don't resurrect 3 year old threads... people are going to be responding to the original post, not your continuation on Page 2.
                    The Prelude Si should have an H23A1 in it. The F22A1 came in the Prelude S, and was identical to the F22A1 found in the Accord... and it was SOHC. If you have an F22A1 block with a DOHC head, then you do indeed have a swapped head. Look for stamps on the head to identify it.
                    All transmissions are interchangeable between all F and H engines. They bolt right up to the block, and will shift exactly the same way. If you have difficulty shifting to 5th, it may be a clutch issue, a hydraulic issue, or an internal wear issue within the transmission itself.
