Setting the timing after swap
    I just swapped a newer f22a1 into my manual 90 lx sedan. The engine came out of an auto 92 wagon. The wiring harness from the 92 is slightly different then the wiring in the 90 so I swapped the old intake and dizzy onto the new engine and used my old harness, and I also put a brand new flywheel on. There are no marks on the new flywheel for me to sight through the pointers in the bell housing so now I am wondering how i go about setting the timing.
    With no marks, you can only guess. You should have lined up the old flywheel and put marks on the new one before you installed it.
      yea you can pretty much line up the cams at tdc as best as possible and then mark it through the inspection hole.
