seafoam in vacum line
    I'm wondering which vacum line to put seafoam. And its location, thanks
    Brake booster. Search there's lots of info on it here. The standard I believe is part in the brake booster, part in the oil, part in the gas. I'm thinking 1/3 brake booster, 1/3 in the oil, and 1/3 in the gas tank.
      Thanks, I tried to search first but I'm on my phone and it wont let me for some reason
        http://www.cb7tuner.com/vbb/showthre...hlight=seafoam
          From what i've read you will want to change your oil shortly after.
            ONLY if you add the Seafoam to the crankcase.
              Yep. That was should he follow the 1/3, 1/3, 1/3 recipe I posted.
                I rarely use Seafoam in the crankcase, I generally only put it in the intake and gas tank. I think Synthetic or tranny fluid is a better " engine " cleaner, your only adding a few ounces of Seafoam to the oil.
                  I put 1/3 in gas tank 1/3 into the oil and 1/3 I put through the vaccum hose using the pcv valve for controlled suction.
                    Thanks everyone, great link btw
                      Of course it's a great link, I was part of it!
                        I did it and it smoked out the whole trailer park lol, yes I'm poor and live in a trailer park
                          FOR LIFE!!!!
                            I have heard of cats using tranny fluid to clean out their engines. Though I would use Seafoam, just for the fact its specifically designed for that purpose.
                              True, but using Seafoam in the crankcase REQUIRES an oil change, tranny fluid does not. If I can save some money on an early oil change, I will.
