I been having this problems for over a year. my car just shut of on me one day. after no mechanic could find the problem i changed the fuel sensor and it worked fine for like 3 months. after the car felt like it lacked power. I would give it gas and it seemed as if it would shut off. this happened for 3 days untill it shut off n it wouldnt start. I got a motor swap done to it hoping this would fix the problem but nothing. I have changed the ecu to a p13 and to a p28, changed distributor cap, radiator, fuel pump, spark plug wires, checked timing fuel lines changed oxigen sensors, and the problem is still unfixable. can n e one help plz!!!!
91 accord problem no power after 5k rpms
Originally posted by Ubettermakeway View PostI been having this problems for over a year. my car just shut of on me one day. after no mechanic could find the problem i changed the fuel sensor and it worked fine for like 3 months. after the car felt like it lacked power. I would give it gas and it seemed as if it would shut off. this happened for 3 days untill it shut off n it wouldnt start. I got a motor swap done to it hoping this would fix the problem but nothing. I have changed the ecu to a p13 and to a p28, changed distributor cap, radiator, fuel pump, spark plug wires, checked timing fuel lines changed oxigen sensors, and the problem is still unfixable. can n e one help plz!!!!this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Oh, first... what engine are you running now? What ECU? What else has been done?
Is your ignition timing properly set? Is your valve timing properly set? Is the engine healthy (have you done a compression test?) Is your catalytic converter clogged?
Since you said P13 and P28, I'm assuming you have an H22A. Does does the VTEC crossover occur?
Since you've swapped, that increases the chance for error on your part greatly... so it may be difficult to diagnose the problem without knowing every little detail.
Originally posted by Accord problems View PostMain feul relay or igniter.
