Engine clean up
    Engine clean up
    I removed all of the intake box,cruise control, and the wiper spray bottle. Any ideal on what can b done next without removing ac nd power steering
    http://www.cb7tuner.com/vbb/showthread.php?t=188849
    Ideal?
    Look at your engine bay. Anything you don't need, remove it.
      what is the small clear box by the battery that has a plug at the bottom. Also above the bottle that holds the water spray there is a small canister i believe is a vacume . Is that required?
        inside passenger side fender there is about a pound or two of plastic that is absolutely useless!
