i am having the Idle from in my F20A CB7,,,, 2 months back while changing the Transmission, i noticed that one of the Injectors was leaking,,and the technician put a washer into it and problem was solved,
1) the injector was leaking and Washer was put into it and leakage was stopped
2) Canister is broken from the TOP,only one pipe can not be fitted,,,
3) i have set the RPM on 1100 on Warm and on turning on the AC, the RPM drops till 300-400 and start studdering
4) i have never changed the fuel filter
,,, i will change the fuel filter today,,but IAC valve have been cleaned,,,what else?what further step shud i go to?is canister that important?
