Originally posted by wed3k
View Post
swap failed smog high hc(ppm)
Originally posted by wed3k View Postbecause it affects emissions?
1- fuel cap
2- visual inspection for the cat. (they slide a mirror under the car)
3- they do the tail pipe sniffer test.
If the testing center (or shop) is checking the timing (and they must be), he is going to have to correct whatever the issue is. I was going to say if it was like the area where i live, and if his car is close to passing, sometimes you can just retard the timing a bit, and it will pass. I am sure of this because it happened with my car. And after some calling around to local shops, they told me this is how they are getting some cars to pass (i am referring to retarding the timing just to get the car to pass). I don't agree with it because it makes the whole emissions testing thing a joke.
But from what he is writing above, that may not be possible. My bad if I caused any confusion. Good luck.
