corner lights help
    corner lights help
    so my corners arent working. the bulbs are good, the fuse is good, and they're hooked up but they wont come on. all the other lights on/in the car are working how they should. idk what the problem is :/ any ideas?
    Pull out a test light / multi-meter and check for power to your lights. If no power trace the wires back till you find power. To me it sounds like you might have an issue with the "running light" portion of your combination switch.
      are you talking about your parking light or turn signals in the corners or both?
        i have the same problem but im about to test the wires right now....is this a common issue? And i also have a 92
          both. I'd hook a test lamp up to it but I fried mine trying to fix a computer for a friend :/ lol
