harmonic balancer bolt
    Yeah that bolt. The tightest bolt on our cars. I am putting a motor together for my other cb7 and I cant get the bolt off.
    I have tryed
    250 foot pound impact @ 100 psi
    Harbor fright 500 foot pound impact with heat @ 100 psi
    the tool that holds the harmonic balancer so you can crank on it. I was jumping on the wrench.
    what do I need?
    Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
    93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
    are you using extensions between the socket and the impact? if you are, don't and that will help. is 100psi the highest you can get? obviously you could try more if you have the option.
    '94 CD5 EX F22B1 Automatic
      the nifty little tool that holds the crank while you crack the 19 loose, i got mine from matco, look it up under specialty tools in tas auto. ive seen cheap ones break or wanna strip. worse comes to worse get a big ol bar on the end of that breaker bar
      If your trans is still attatched, pull the timing plug and stuff a prybar in the flywheel teeth and have someone break the 19 loose GL
        I tryed that tool but the motor is not in the car so I cant crank to hard but I jumped om the wrench and tryed a big braker bar.
          Have you tried combining penetrating lubricant AFTER heating it? Right after torching the nut, spray either PB Blast or Tri-Flow (it's an industrial product, so the internet's where your gonna find it) on the bolt, and as it cools, it'll suck the lubricant right in. Out of preference I'd use those two, but I'd use WD-40 if I didn't have either.
            i used the crank pulley holder tool wedged against the floor and a 3 foot breaker bar to break it loose.
            also used a lot of heat and penentrating oil
            ingersoll rand impact gun backed with a lot of air pressure
              This man knows whats up^^
              Also, if you think its rusted stuck... 50% automatic transmission fluid and 50% acetone is one of the best known rust penetrants.
                Yes you will definitely need the Honda key for the crank.
                Then use a an impact socket (black molybdenum). I recommend the 3/4 (not 1/2 inch) size extension and 2 x breaker bars (all in 3/4 inches).
                One breaker bar stabilises the key (against the floor).
                Place the impact socket on the bolt.
                Connect the extension to the socket and support with a jack stand
                Connect 2nd breaker bar. Use a cheat pipe to increase the length/leverage (torque power). My cheat pipe was 6 ft long.
                You can spray/or hit it the bolt with heat (blow torch) prior to turning
                Turn the bolt towards the front of the car (anti clock wise)
                Not very difficult with that kind of set up.
                Rides:
                Accord
                92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
                96-AUDM-2.2 VTiS- Heather Mist
                CR-X
                88-JDM-Si- Black
                CR-X Del Sol
                92-JDM-SiR "Transtop" Motegi Edition - Silver
                95-JDM-SiR "Transtop" Daytona Edition - Silver
                92-JDM-SiR "Transtop" - Black
                Prelude
                91-JDM-Si-4ws "Si States" - Phoenix Red
                91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
                91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
                91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
                  I will try oil and more air
                    on mine i had a about 8 foot bar attached and about 200 pounds on the end of it to break it loose.. after i had sprayed it 32974 times the night before with PB blaster... so needless to say... air most likely wont work(it may... but...) so try to get the longest pipe u can...
                      what model number of gun?
                        Ingersoll-Rand 2135TI
                        1000ft-lbs
                        great for breaking/shearing bolts but you need good air pressure behind it. shop air is 150 psi.
                          u need 3 people 1 to hold eng and 2 each with a bar, one holding the crank pulley the other the 19.
                            I just used 2 bars, I had one, my friend had the other, we had the bars up top and pushed towards each other. It came right off, and it was on an engine stand.
