More problems, leaking oil.
    No matter how much I do my best to take care of this car, she keeps shitting on me.
    Noticed a small puddle underneath the car. Oil is leaking where the transmission meets the motor, its leaking very slowly. But it looks like theres a rubber gasket I am guessing that will need to be replaced. Also noticed that the oil pan at the top where it bolts on is very wet with oil, so I am assuming that this needs replacing too.
    So, I would like to do this myself, I know it is going to take a lot of work, My uncle told me that the transmission will have to be dropped. Before I go buy a gasket, I need to know how to determine what type of transmission I have? I bought the car with the swap done. Auto to manual. Previous owner said it was lsd, but I've found many things he said to be false. So I would just like to confirm before buying the wrong gasket. Thanks.
    Everyday is one day closer to completing my cb7 <3
    are you sure that this is the problem? when i first got my CB it had a gradual oil leak that turned in to a HUGE oil leak. i searched and searched on the forum and all arrows pointed to the sender unit above the filter. it was a $7 part and a bitch to get to but it stoped the leak. Have you gotten a chance to do a good degeasing? the soiled oil spots might be buildup from a problem elsewhere. i may be totally wrong but the sender unit took care of my leak.
      I was sure until reading your post. I mean I've only taken a look at it. You're right. I'll clean her up nice, and then look again. Now that you mention it, your post makes even more sense because the oil is not just pooling in one drip, they're like small blobs along underneath tranny. and it doesnt leak all the time, only now and then. Like right now, i just took a look and there is no fresh oil spots.
