I was just using it the other day. Now it wont even blow air out.
Heater not blowing
Originally posted by gvaldez92 View PostAre they easy to fix never done either.
Oh have you checked your fuses at least?
EDIT: Did a quick search, and heres a link to replacing the blower motor. INT : Removal/Replacement of blower motor
Oh and to get access to the blower motor resistor, you pretty much have to get access to the motor itself, heres some information in regards to testing:
Originally posted by YK86 View PostSet the fan speed to max and test the 2 wire plug by the passenger kick panel. There should be 12V. If there is 12V and the blower doesn't work at any speed, the blower motor is dead. If the resistor was dead, it should still work at max speed.
When the motor dies, it's almost always the brushes inside that have worn out. If possible, it is a better bet to buy a new motor as the junkyard ones are just as old (unless you get lucky and find one with a motor that was just replaced). I only say this because these cars can be a pain in the ass (especially the ones with A/C) to swap out as you need to remove the whole blower box from under the dash unlike the older and newer Accords where you can just pop the motor out from underneath.Last edited by cloudasc; 03-11-2012, 05:37 AM.
