loose shifter?
    loose shifter?
    My 5 spd coupe shifter is really wobbly like i can move it around in circles when in neutral. is it supposed to do that? or not?
    Yes. Unless you have a gated shifter like you'll find on a lot of manual transmission Ferraris and Lamborghinis then it's going to have play.
      alright then didn't know. Thanks!
        there are two bushings you can replace that'll help the shifter feel more direct. The problem is, you either have to buy the entire shift cables from Honda since they don't sell them separately or buy the shifter bushings through a company called Corsport. Option two is way better for 32 bucks
        http://www.corsportusa.com/store/cat...oducts_id=2218
        you could also get these for the base of the shifter to improve feel even more for another 30 bucks...ah well these second ones might not work. I can't find an application for 90-93 accords but you could do some research and find out if other cars are compatible from the drop down menu with the cars they listed.
        http://www.corsportusa.com/store/cat...oducts_id=2219
        I'm probably going to get the underhood bushings first for my DD since its WELL worn out at 259k miles. There's gotta be at least an inch and a half of slop between the gears fore/aft when in neutral
          Alright then I think I might just do that. Thanks!
