So iv finally decided to clean up the h22 and find/fix all my little tiny oil leaks(if any at all, could just be there from before or what not...
but anyways to the topic what should i use to clean the motor with... i know it will need to be something sensor safe, also i dont want to use something that will eat my gaskets, as i dont want to replace something i dont need to.. any thoughts are welcome, experience would be nice also.. i dont want to be out there scrubbing for 10000 hours though either(yea im a bit lazy, but try not to be -_-)
also when washing off the cleaner, is there anything i should worry about getting water on? i mean the dizzy is sealed(to my knowledge, which TBH isnt the best) as long as i dont just jump in the car and start it up, either let it air dry(which may cause water spots) or blow it with a fan/vacuum or w/e else your little imagination can come up with =P!
list of non-corrosive cleaners
as it seems so far that iv researched pretty much anything citrus based is non-corrosive, so are far as those, im not going to list.
oil eater
oil eater
