I just got a 5spd transmission from the junkyard, and its leaking fluid from the motor/drivers side axle housing. Does it just need a axle in there or is it most likely the outside seal or even worse the inside seal? Thanks
Junkyard transmission leaking.
Since the axle is not completly in his place and completly locked, its normal you lost oil by the axle hole. if this continue to leak after the axle is on his place, this will the seal in trouble.
put the axle and look oil level after completed the job and looking if he has some oil leak.... im sure you dont want burn your tranny.
good luck!
