brake pedal sinking
    Yeah ok I probably never bleed the brakes since i first got it 3 years ago. Maybe its time for some brakes and a bleed.
    Thank you.
      Thank you.
      If youre feeling froggy do the piston seal and dust boot on the calipers. If youre feeling lethargic, flush the system, and bleed. Check your hoses while youre in there too if they feel spongy then it may be time to upgrade/replace. If you have the ends now'd be the perfect time to upgrade to stainless steel braided lines and the MC. Hopefully your fluid is just beyond its life and giving you problems.
        More often than not, though, such a drastic decrease in pedal pressure is due to a failed master cylinder, not old fluid.
