Ugh. After a fun filled day of plug replacement and valve gasket replacement.
I'm still having an issue with the car running.
Earlier this week it starting sputtering and eventually wouldn't start,
It's getting fuel and I checked the plugs. The plugs were covered in oil.
I put the new plugs in, valve cover back on.
It started right up and ran like a champ, turned it off, started it again. And guess what, it's sputtering again. I looked under the car, and oil was steadily flowing down the back of the block and was dripping off the filter. It appears to be coming out of a sensor above the filter.
It doesn't explain my sputtering, hopefully you guys can help a rook.
I'm also having some coolant usage.
She has 267k on her btw.
