external harness internal dizzy question
    okay i have a harness that im redoin resleeving and stuff but its for a 92 external coil. i want to keep my internal coil dizzy but continue to use this harness cuz im pretty far into it. has anyone did this?
    what is required?
    i cut the dizzy plugs off a internal harness at the jy i figured i could replace the connectors on the external harness.
    info anyone? thanks
    -Tyler
    i will have to look thru my notes but if i remember correctly you need the plugs from the internal harness to wire to your existing harness, your gonna need to basically figure out which wires are for what, i had it written down somewhere but i think theres a writeup on here somewhere. i would just as easily grab a internal harness from the yard and start there but thats just me. i will post up when i find the pics and notes i had.
      You actually WANT to keep the internal coil? People usually convert the other way!
      If it's not raining tomorrow, and I remember, I'll see if I can snap a picture of my H22's setup. The shop that did my swap converted my 92 to run the internal coil. It's a shitty job, but it's worked for 9 years... so they did something right, at least.
      You could use that bit of harness you clipped at the junkyard to create a subharness, so you don't have to cut your stock wiring. That would be your best bet. ALWAYS avoid cutting your car's stock harness if you can help it.
      Honestly, though... you'd be better off getting a proper external dizzy. The internal ones tend to kill the coil faster, due to heat exposure (of course, "kill them faster" seems to mean 10-15 years minimum! )
        yeah i hear that but i look at it as one less 8mm wire in the bay, all on preference i guess. plus ive never had an issue even when it was cracked when it rained with the internal, my cd on the other hand when it was stock with external that was another story might as well have yanked a plug out and drove lol i was a bit cheap to go and buy a new coil haha.
          If you want to keep your internal coil, just cut the plug off of the harness that was for the existing coil, and splice together the yellow and black/yellow wire. Then cap the white/black wire. Then just plug the distributor into the 2 plugs you already have on the harness. You shouldn't need any extra plugs.
            ^Good point. He could also simply leave the plug entirely and bridge the 2 connectors w/ a 30a fuse.
              as ive been researching i saw a banned member on here do that.
              makes sense i just didnt know that the plugs were the same.
              but thanks everyone for the suggestions i was in a rut.
              and i also didnt know pros and cons of external vs internal
              internal to me is one less wire and one less part to mess up (although the coil is inside the internal one) but physically..
              thanks all!
              -Tyler
                Who was the banned member?
                  http://www.cb7tuner.com/vbb/showthread.php?t=84028
                  d112crzy
                  -Tyler
                    Ah yes.
                      dan is correct, just put a 30a fuse in the plug for the external coil and it will work perfectly
                      instagram @mikeymeyagi
                        sweet
                        this saved alot cuz the harness is already de loomed ready to be de-pinned.
                        im gonna take the white/black wire out the harness completely.
                        and join the two other wires together at the beginning of harness
                        chase bays? nah this tyler bays haha
                        -Tyler
