Rear hub and bearing removal?
    Can anyone give me a quick DIY on removing the rear hub with bearing. My left rear has finally giving out. Can I simply unbolt it or does it have to be pressed out.
    -With a flathead, remove the cap covering the axle nut.
    -Unstake the Axle nut, and remove. You'll need a 36 mm socket. There will be a washer as well, don't lose this.
    -Spray lubricant liberally behind the bearing as well as inside the spline.
    -Using a flathead or prybar, carefully wedge it between the hub assembly and the knuckle and muscle it out.
    Normally I'd have helped you search for it, but TBH I didn't find a specific thread either. I made this in 2 min with spare parts laying in my garage. * Note for all the nitpickers, The axle nut looks a bit diff because i used a prelude nut in the pic as well as a prelude knuckle. Same concept.
      Thank you for the guide, Mrik. Reputation to you. I needed to do this myself.
      ||91 Accord EX|| All of my images are hosted courtesy of imageShack.com
      Door-Sensor fix (DIY)||Interfacing Arduino to Power locks
      RICE = Race Inspired Cosmetic Enhancement.
      "The greatest advantage of speaking the truth is that you don't have to remember what you said." - unknown
      "That's the funny thing about parts that break... they're never broken until they are!" -deevergote
        Whoa rep points to u, that is a great amount of help! U should consider makin a DIY .
        How would we know when our hub n bearing is beginning to go bad?
        RIP '91 LX.
