Ok so i just finishd my h22 swap, still got idle problems and the main problem is the car doesnt move ?? it drives like 5 mph ? What can that be
h22 swap done but the car wont move
Originally posted by ricancb7 View PostYea i did the swap lol it was my first h swap. but yea check engine light is on maybe cause it has a bad idle i revs up and down, and could it be the throttle cable. ?
We can sit here and take guesses at what it could be all day..... Best option would be to check your ECU for the diagnostic trouble codes. They will be more likely to point you in the right direction.
what year h22 and what ecu are you using?2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
"Limp Home Mode" or as Honda refers to it as the Fail safe Back up mode. Is when the ECU is missing signals from vital sensors and it reverts to a safe set of fuel and ignition maps. It will not allow the engine to rev over 3500 rpm. It is usually enough so that you can get the car off the road or "Limp Home".
The TPS is on the fire wall side of your throttle body and the MAP should be on top of the throttle body.
If the CEL is on then you can still retrieve the codes from the chipped P28 ECU by using the self diagnostics paperclip method.
Or you could find someone with a laptop, tuning software (Crome, eCtune or Neptune) and the proper hardware to hook it up and actually tune it!
What basemap do you have on your chipped P28? Do you know if this ECU has ever worked in another car?Last edited by GhostAccord; 02-29-2012, 02:44 PM.
Originally posted by djcaz_aom View PostWhy don't you pull the codes first? It will save you from random sensor checking.
loose thermo ground or disconnected on can cause major amounts of problems had that happen to me before and the saftey switch for the shifter clicked with my turn signals start it grab a papper clip and look under the passenger side glove box for the code puller and read the codes on the cel if you dont know how to do that then you should have someone who knows what there doing look over the engine chances are if this is your first swap you got a vacuum line mixed up or like ghost said you have a sensor problem just pull the codes kid
