vtec question
    vtec question
    hey guys,
    i'd like to ask if a v-tech head fit on a f-22 a1 block? it migjht sound dumb but is was just thinking out loud.
    [IMG]http://
    v-tech is a wireless telephone brand, V-TEC is the sound you like!!!
      *VTEC first off.
      Yes it will but with some serious modification. And if you have to ask if it can be done your probally not ready to do what needs to be done.
      STANCE|WORKS
        What's the point of having vtec on a bottom end that can't take advantage of it???
        wat?
          that's why i asked. pardon my extra "h" my phone works fine.
          [IMG]http://
            Originally posted by bravedude View Post
            hey guys,
            Frankenstein motors are dumb, use the head that goes with the block, there is a reason why they made a different head for each block(in most cases) if the block was made for the head... they would have put that head on it
              This has been addressed over and over and over and OVER and OVER on this forum. Your "h" clearly works fine, but is your search button broken?
              Will a VTEC head fit? Yes. The F22B1 head will fit easily enough, and it is a piece of crap head that is worse in terms of performance than your current F22A head. All other VTEC heads are matched to a larger cylinder bore, so they will not fit without the risk of a detonation-inducing ridge in the combustion chamber. Also, the F22A's compression ratio is very low, and the redline is not very high... so you would not be making much power with a VTEC headswap.
              Now, because you're too lazy to search, and I abide by my own rules (simply telling someone to search is against the rules here), you just wasted MY time instead of your own to answer this question. Next time, try searching. I know this question has been answered about 2 dozen times in the past year... because I've answered it myself each time. The answer doesn't change.
