Originally posted by Bad_dude
View Post
Still Getting Bad Gas Mileage
this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View Postok my gas light came on this morning right at 332 miles same as my last tanke after the fix . thanks to all that helped me you know who you are.
Thanks.
Originally posted by Bad_dude View PostSo base on this, your gas mileage is around 22 mpg. Was it lower when you had the problem? So you had both bad TCU and ECU? I was hoping for higher.
Thanks.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Bad_dude View PostSo how many miles did you get before the gas light comes on with the 32mpg?
Car safety checks
Fluid Capacities
Originally posted by Accord problems View Postbefor fix 178 miles two a tanke now its 320 + miles to a tanke i have not pushed it to the light . ive hered that is bad . i dont drive like the world is my race track .
Where did you get your capacitors? Hong Kong?
Thanks.
Originally posted by Bad_dude View PostSo estimating 320 miles to 14 gallons. That's about 22-23mpg. I think that's the best for an auto. So what's up with all of these 30 mpg that I see. Could a manual be that good on gas mileage? Did you solder your own capacitors?
Car safety checks
Fluid Capacities
Originally posted by Accord problems View Postas for the stick shift it has a 5th gear that the auto dose not have so it is possible its all about how you drive . the capacitors i did my self got them from radio shack . the ecu was to far gone so i gave it to a recycler . its not hard takes time . it all comes down to you and what you wont to do .
Originally posted by Bad_dude View PostI can solder, I have done smaller stuffs on my computer components. Not a big deal. I want to replace for my ECU as well. I don't drive my car hard at all, I baby it. I keep it in good shape and maintain well. I was just wondering if I could get better gas mileage out of it.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Thanks.10th Anniversary Accord.
05 Audi A4 Ultra Sport 6MT.
Originally posted by 10thAnnivCB7 View PostIm getting about the same as you just said on highway miles ,, i drive another car in the city just because i want to keep it as clean as i can
up date full tanke of gas 345 now retarded my timeing to where it needs to be .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
is it mainly hiway driving or city driving cause mines a mix of both . On the hiway I can score upwards of 34-35mpg in the city its about 25-26mpg And I do mainly city driving. I noticed one of my tires keeps getting flat (and it butt fucked me out of mpg) so atleast tomorrow Im getting my tires!!!
