Still Getting Bad Gas Mileage
Last edited by Accord problems; 03-01-2012, 04:57 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
so what do you think cloudasc?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
ok i went bye a shop today called walker automotive . they told me that i do have a faulty ecu . that even if it store's codes that there is something else wrong with it . i will get to honda and see what they say .so what do you think cloudasc?Last edited by Accord problems; 03-02-2012, 02:31 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Its definately not shifting like it should. That would be a great reason why your getting bad gas mileage. Change the tcu, or attempt to fix the one you have, it should fix the problem.
After replacing the tcu fixes the issue (which it should), I would personally raise hell with whoever did the work on the transmission (you said Honda did in a previous post?), as they charged you to fix something that didn't need to be fixed, IF your car was acting like this before "they" changed the transmission.
Originally posted by cloudasc View PostIts definately not shifting like it should. That would be a great reason why your getting bad gas mileage. Change the tcu, or attempt to fix the one you have, it should fix the problem.
After replacing the tcu fixes the issue (which it should), I would personally raise hell with whoever did the work on the transmission (you said Honda did in a previous post?), as they charged you to fix something that didn't need to be fixed, IF your car was acting like this before "they" changed the transmission.Last edited by Accord problems; 03-02-2012, 05:08 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Turbo617 View PostHas it been fixed or no? ^Last edited by Accord problems; 03-18-2012, 03:57 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by cloudasc View Post^^ So I take it you repaired/fixed your old tcu then? Did all you have to do is replace the capacitors? Or did you just find a suitable replacement?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
ok my gas light came on this morning right at 332 miles same as my last tanke after the fix . thanks to all that helped me you know who you are.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by tm123 View Posthey bro im in the same boat
135 miles on half a tank..
s light flashing
cel
car even went into limp mode on start up the other day but hasnt done it again after reset.
Dude cloudasc knows what hes talking about if not for him my car would be parted. Do as he said pull the codes and check for leaking capacitors and transistors . Ass they age they brake down and leak out goopy stuff and dont work or function right at all . This was my case. Like I said cloudasc knows his stuff . Point for you cloudasc .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
