Napa Camber Kit
    Napa Camber Kit
    Hi I know theres a thread already, but I didn't want to hijack it so my question is how good are napa camber kits. All it looks like is an eccentric washer. Heres the link.
    http://napaonline.com/Catalog/Catalo...980_0066278917
    1991 Honda Accord 2DR LX 180,000 Miles RIP
    That's not compatible with our cars.
    If you click the link at the bottom that says "buyer's guide", it goes to a page full of Ford trucks.
      http://napaonline.com/Catalog/Catalo...(P_RecType%3aA)
      there is the 2 from napa for our cars, rear is first.... idk how good they are... so deev or someone else will have to answer it
        seems i cant get both to work in the same post for some reason, or even on this one... idk sorry
        part numbers are
        front - NCP 2641979
        rear - NCP 2643686
          part numbers are
          front - NCP 2641979
          rear - NCP 2643686
          It just looks like a bunch of washers. Just go to hardware store and save yourself the trouble... and money.
            im dropped at least 3-3.5 inches. camber kit is not required. my camber is -0.3 tow 0 caster 0. as long as your tow is 0 your tires will be ok. camber has minimal effect on tire wear.
            get a firestone alignment dont get a cheap ass one
            [COLOR="Magenta"]
              Yeah except without one your car looks hella foolish.
                Camber has an effect on tire wear, period. That's all that matters.
                  It does, but you kind of have to be at the extreme to kill some tires.
                  I ride around every day at -2 degrees on both sides in the front. My current set of tires have about 35k mi on them. They will need to be replaced before summer. Camber wear on them is not very much at all.
                  Gary A.K.A. Carter
                  [sig killed by photobucket]
                    My main point is the fact that people will ignore the camber wear and see the center of the tire thinking "oh, that's still good!"
                    Even if camber wear isn't going to destroy your tire in 5,000 miles, you should still be mindful of it, and inspect the tires from time to time. Plus, if the toe is off, the inner edges of the tires will get destroyed very quickly, while leaving the outside and center in relatively good shape. I learned this when my camber kit broke, and I replaced it with the stock parts... and never got an alignment again.
                      The aftermarket camber kits have been discussed over and over. But is there a decent alternative for just replacing the stock on? I'd prefer at least not cheap Autozone Duralast part...
                      Dylan Prichard : 812-595-1072
                      92 cb7: DX, coupe, 5spd, leather.
