Car is Stuttering???
    I have a 91 accord.and around last week it started stuttering when i would turn it on.After warming up and running it for a bit it stops doing it.also.the break light would come on and turn off before this happen.now it stays on.could it be the spark plugs or maybe the o2 sensor??
    heres a vid when im warming up the car.
    http://www.youtube.com/watch?v=fhp3q...ature=youtu.be
    heres when it starts to wrm up and it idles
    http://www.youtube.com/watch?v=5W7Zq...ature=youtu.be
    and heres another one when it warms up and it idles with no stutter
    http://www.youtube.com/watch?v=ZieRR...ature=youtu.be
    all help is greatly appreciated
      I checked the brake fluid ands fine so im guessing the light isnt cuz it needs fluid
        can anyone help me please im trying to fix this
          That exhaust is terrible!!!! Fix asap!!!!
          But if your tach is bouncing like that, definitely a vacuum leak or your idle air control valve is broken. Try that and see what happens. As for the brake light, I couldn't say. But alot of shops nowadays do free brake inspections; I personally go to Goodyear they always give it to me straight.
          '94 JDM H22A: 178whp 146wtq
            ok.how do i go about fixing the vacum leak?
                is this to fix the vacum leak??
                  you can try spraying carb cleaner on the vacumn lines to see if it "boggs down" ... or visually inspect to see if any are off or dry rotted
                    clean the iacv, there is a DIY sticky look at that.
                    look for vacuum leaks
                    also look at your fitv - another DIY sticky
                    basically just go to this thread
                    http://www.cb7tuner.com/vbb/showthre...t=erratic+idle
                      A stutter:
                      Can be caused by - A faulty o2 sensor, check to make sure it's working.
                      Spark plug wires arcing out.
                      Spark plugs are to cold causing fouling, run a hotter plug with a smaller gap, I preffer .017-.026 depending on upgrades.
                      A faulty injector not pulsing.
                      a iacv will cause more of a hesitation and idle surge.
                      coolant in the combustion chamber, the same goes for oil, yet your plugs will tell you if thats happening.
                      Water in your gas.
                      A dirty fuel filter
                      "Self Renewed"
                        Originally posted by KeeleDesign View Post
                        A stutter:
                        Water in your gas.
                        A dirty fuel filter
                        Thanx alot.i will check every options.
                        and thanx keeledesign for giving me a check list
                          The 2nd and the 3rd videos, are those when you put your foot on the pedal to keep it from shutting off or is that how your car is without the foot on the pedal?
                          Check the sticky throttle and cable.
