WOULD it be leaking out of the headers cause bad rings or bad valve seals it does smoke only when i step on it. I got a 92 CB7 2dr with a single cam f22b1 vtec still pulls hard but i havnt ran rough since i first saw the blueish greyish smoke? What would be make the oil leak into the chambers help if you can thank you.....
oil leak from headers?
Just one header, not headers.
Anyway, piston rings are most likely the problem. Valve stem seals could be another cause. Either way, oil is clearly getting into your combustion chambers. The blue smoke is burning oil, and the leaking oil is... leaking oil. It shouldn't be there. That engine has to come apart.
Compression/leak down test.
02 Crv
