Low gearbox oil
    Low gearbox oil
    I have a 90 EX, manual tranny. I had a bad CV joint, so I changed the right axle. While removing the old one, some oil leaked out (less than a pint). I thought that I should top it off to replace the loss, but I couldn't get the plug unscrewed.
    Should I be worried about this? It seems to run and shift fine.
    if only a pint spilled out when you removed the axle, you are WAY low on tranny fluid my friend.
      OK, so I'll take another stab at the plug.
      Any recommendations on the oil? Somebody told me that these cars just take regular motor oil in the transmission, is this right?
        Yup. I believe it's 10w-30. That's off my head though so I could be wrong. I would change oil while your at it though. New oil lubricates much better than old oil!
          I would only ever use Honda Genuine Manual Transmission Fluid in my transmission....
          others use GM syncromesh....
          92ex CB7<-SOLD 93ex CB9shiftingshift73C10
            Manual transmissions aren't as sensitive as auto's. I've had pennzoil in my transmission for 1 1/2 years now and it shifts smoother than it did when I first bought the car!
              Try Honda mtf and it will shift even better..
              wat?
                I'll try that out next time I do an oil change. I've heard that GM syncromesh is better than Honda MTF though I'll have to try them both out and see which I like better.
                  they came out with a revised version. i actually ran a combination of both. saved the synchros all the way till 267k when i sold it.
